It is currently Tue Jul 29, 2025 6:41 am
PostPosted: Sat Oct 29, 2005 8:18 am
Anyone here made wood tuner buttons, or care to share how they're made, in detail (with photos please)
TIA
PostPosted: Sat Oct 29, 2005 11:47 am
vs just buying custom wood buttons?
http://www.nicholsguitars.com/tunerbuttons.htm
PostPosted: Sat Oct 29, 2005 12:22 pm
Hi Brock,
Yes. I Thought the process would be interesting to discuss. Craig's cool router jig would be indespensible, I think.
I EM'd Bill to see how much a set of Coco would be.
PostPosted: Sat Oct 29, 2005 3:32 pm
I have thought about using Craig's gizmo, (or a custom jig built on a similar idea) but just haven't gotten around to really playing with it.
If you come up with something please share.
PostPosted: Sat Oct 29, 2005 3:57 pm
Ditto. I'd like to see how it's done. Maybe I'll do some serious thinkin' on that this winter when painting slows down.
My banjo guilding buddy is quite the craftsman, and would very likely just make em by hand and eye. He does a lot of heel carving, metal and pearl engraving too. He's very good, and an ispiration.
PostPosted: Sat Oct 29, 2005 6:02 pm
Oooooooooo, those are so nice! Thanks Brock.
PostPosted: Sun Oct 30, 2005 1:16 am
Here is another thought about how I might approach this (For Schaller type buttons) -
make a flat board that sets on my vertical edge sander, then have an attachment on a pivot pin that will swing the button in an arc at the right radius to put the proper curve on it. I am guessing you would either stick the button down with tape or a destaco clamp
(You would need two of these pivot arms, one for the front edge and one for the back edge)
I am not sure if it would be better to put the edge radius on it before you put the curve on the top and bottom, or after.
Again... just some thoughts I had. I haven't really messed with it yet.
PostPosted: Sun Oct 30, 2005 1:31 am
Also you could take a longish board and put the radius on both sides of the whole board (production style), drill them, then cut them out, profile tops & bottoms
Haven't thought it through much. I might try to make a set just for fun. It looks like there's inserts in the holes on Bill's site
cron
